Motion Cursor preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
In this showcase preset, you tilt the whole controller and the pointer moves with it, returning to the same spot when the controller returns to the same angle. The face buttons click and the right stick scrolls. For someone who can hold a controller but cannot work a stick, it is a real alternative to a mouse. It works on the DualSense, DualSense Edge and DualShock 4, and on the 2026 Steam Controller (experimental).
Slower than Gyro Aim, with clicks and scrolling on the buttons; good for couch desktop use on a DualSense or DualShock 4
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Right stick down | Scroll down | variable sensitivity; deadzone 18% | Scroll down |
| Right stick up | Scroll up | variable sensitivity; deadzone 18% | Scroll up |
| A / Cross | Left click | Left click | |
| B / Circle | Right click | Right click | |
| Y / Triangle | Return | Return | |
| LB / L1 | Pause Motion While Held | Hold to pause motion | |
| RB / R1 | App action, App action | Re-zero gyro, center pointer | |
| Gyro Y (yaw) + | Mouse motion right (speed 6) | variable sensitivity; Smooth curve; deadzone 5% | Tilt right: pointer right |
| Gyro Y (yaw) - | Mouse motion left (speed 6) | variable sensitivity; Smooth curve; deadzone 5% | Tilt left: pointer left |
| Gyro X (pitch) + | Mouse motion up (speed 6) | variable sensitivity; Smooth curve; deadzone 5% | Tilt up: pointer up |
| Gyro X (pitch) - | Mouse motion down (speed 6) | variable sensitivity; Smooth curve; deadzone 5% | Tilt down: pointer down |
11 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Re-center. R1 makes the current tilt the neutral and puts the pointer in the middle of the screen.
- Move without moving the pointer. Hold L1.
- A shaky hand. Lower Speed on the motion rows.
Lower the speed before anything else if the pointer feels jumpy.
Download
- Motion Cursor presetWave the controller to move the cursor; face buttons click 8 KB
