Built-in preset
FPS (Xbox) preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This is the Xbox layout for first-person games with no controller support. It is the same scheme as the DualSense preset with Xbox button positions, so an Xbox player's habits carry over: A jumps, B crouches, X reloads, Y swaps weapons, LB and RB are grenade and melee.
WASD, mouse aim, triggers fire/ADS
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick upWWalk forward (W)
Left stick downSWalk back (S)
Right stick leftMouse motion left (speed 24)Look left
Right stick rightMouse motion right (speed 24)Look right
Left triggerRight clickAim down sights (right click)
Right triggerLeft clickFire (left click)
D-pad upScroll up (one step)Next weapon (scroll up)
D-pad downScroll down (one step)Previous weapon (scroll down)
D-pad leftQAbility or lean (Q)
D-pad rightFUse (F)
A / CrossSpaceJump (Space)
B / CircleCCrouch (C)
X / SquareRReload (R)
Y / Triangle1Weapon slot 1
LB / L14Weapon slot 4
RB / R1Middle clickMiddle click (ping or melee in many games)
L3 (left stick click)ShiftSprint (Shift, held)
R3 (right stick click)EUse (E)
Start / OptionsEscapeMenu (Escape)
24 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Other Xbox-style pads. It works unchanged with the Stadia controller and 8BitDo pads in X mode, which share the Xbox layout.
  • Aim and auto-switch. Tune aim on the right-stick rows, and add the game to auto-switch so the preset follows it.
Habits from an Xbox carry straight over, because every action sits where Xbox shooters put it.
Download
