Built-in preset
FPS (PS5 DualSense) preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This is the DualSense layout for first-person games that only take a keyboard and mouse. Movement is on the left stick and aim is on the right with variable sensitivity, R2 fires and L2 aims down sights, and the rest of the standard shooter set sits where console players expect it. The touchpad press opens the map.
WASD, mouse aim, triggers fire/ADS, touchpad opens map
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick upWWalk forward (W)
Left stick downSWalk back (S)
Left triggerRight clickAim down sights (right click)
Right triggerLeft clickFire (left click)
D-pad upScroll up (one step)Next weapon (scroll up)
D-pad downScroll down (one step)Previous weapon (scroll down)
D-pad leftQAbility or lean (Q)
D-pad rightFUse (F)
A / CrossSpaceJump (Space)
B / CircleControlCrouch (Control)
X / SquareRReload (R)
Y / Triangle1Weapon slot 1
LB / L14Weapon slot 4
RB / R1Middle clickMiddle click (ping or melee in many games)
L3 (left stick click)ShiftSprint (Shift, held)
R3 (right stick click)EUse (E)
Start / OptionsEscapeMenu (Escape)
Touchpad pressMMap (M)
25 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Aim feel. Tune the four right-stick rows: speed for turn rate, Deadzone for drift, and the curve for feel.
  • Gyro for fine aim. Add gyro aim from the gyro page for small corrections from the wrist.
  • Mouse look that stays in the window. The gaming guide covers confine, recenter and polling rate.
Change the right-stick speed first. It decides how the whole layout feels.
Download
