Built-in preset
FPS (Switch Pro) preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
The Switch Pro Controller has its face buttons in Nintendo's arrangement, B at the bottom and A on the right. This preset places the shooter actions by position, so the bottom button jumps regardless of the letter on it, and ZR and ZL take fire and aim.
Standard FPS layout, Nintendo face button positions
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick upWWalk forward (W)
Left stick downSWalk back (S)
Right stick leftMouse motion left (speed 24)Look left
Right stick rightMouse motion right (speed 24)Look right
Left triggerRight clickAim down sights (right click)
Right triggerLeft clickFire (left click)
D-pad upScroll up (one step)Next weapon (scroll up)
D-pad downScroll down (one step)Previous weapon (scroll down)
D-pad leftQAbility or lean (Q)
D-pad rightFUse (F)
A / CrossSpaceJump (Space)
B / CircleCCrouch (C)
X / SquareRReload (R)
Y / Triangle1Weapon slot 1
LB / L14Weapon slot 4
RB / R1Middle clickMiddle click (ping or melee in many games)
L3 (left stick click)ShiftSprint (Shift, held)
R3 (right stick click)EUse (E)
Start / OptionsEscapeMenu (Escape)
24 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • No gyro, no rumble. Gyro aim and rumble are not available on the Switch Pro Controller on a Mac, so this layout has no motion or vibration rows.
  • Everything else works. That means every button, both sticks and the D-pad.
Actions follow the button's position, not the letter printed on it.
Download
