Mouse Keys on a Mac
Mouse Keys is a macOS accessibility setting that moves the pointer and clicks from the keyboard. Its switch is in System Settings, Accessibility, Pointer Control. If the keys U, I, O, J, K and L have stopped typing, Mouse Keys is the likely reason: Apple notes that the keyboard cannot enter text while it is on.
I make InputConfig, a free Mac app that moves the pointer from a game controller instead, which leaves the keyboard free for typing. I cover Mouse Keys first.
  1. Steps
  2. Turn Mouse Keys on or off
  3. Know the keys
  4. Adjust how the pointer moves
  5. If Mouse Keys does not work
  6. Right click and other mouse actions
  7. Other ways to move the pointer without a mouse
  8. The short version
  1. Open the Apple menu and choose System Settings.
  2. Click Accessibility in the sidebar, then Pointer Control.
  3. Turn Mouse Keys on or off.
  4. With it on, move the pointer with 7, 8, 9, U, O, J, K and L, or with a numeric keypad.
  5. Press I, or 5 on a keypad, to click.
  • You: Open the Apple menu, choose System Settings, click Accessibility in the sidebar, then Pointer Control.
  • macOS: Shows the Mouse Keys switch and its options.
  • Check: With the switch off, every key types again.
The options include Press the Option key five times to toggle Mouse Keys. With that turned on, five quick presses of Option switch Mouse Keys on or off from anywhere, and they can switch it on when you did not mean to. If the keyboard suddenly stops typing, look at this switch first.
Know the keys
These are the keys in Apple's guide:
ActionNumeric keypadMain keyboard
Move the pointer7, 8, 9, 4, 6, 1, 2, 37, 8, 9, U, O, J, K, L
Click5I
Press and hold the button0M
Release the buttonPeriodPeriod
Press and hold is for dragging: hold the button, move the pointer, then release it. A keyboard with no numeric keypad still works, on the keys around J and K.
The Mouse Keys options hold three more settings:
  • Initial delay. How soon the pointer gets going when a key is held.
  • Maximum speed. How fast the pointer gets while a key stays down.
  • Ignore built-in trackpad when Mouse Keys is on. The trackpad stops moving the pointer while Mouse Keys is on.
These three settings change how Mouse Keys feels, not which keys it uses.
  1. Check the switch. System Settings, Accessibility, Pointer Control, Mouse Keys.
  2. Use the right keys. Without a numeric keypad the pointer moves on 7, 8, 9, U, O, J, K and L, and I clicks.
  3. Hold the key. Keep it down to keep the pointer moving.
  4. Change the options. Initial delay and Maximum speed set how soon and how fast the pointer travels.
On a keyboard without a keypad, the letters around J and K are the direction keys.
Mouse Keys itself presses the main button. For the rest, Apple's guide points to Alternate pointer actions, in the same Pointer Control settings: it lets keyboard shortcuts, assistive switches or facial expressions perform a left click, a right click or a double click. Turn on Alternate pointer actions when you need more than a plain click.
How to use a Mac without a mouse compares them. Mouse Keys borrows the keyboard, and a controller leaves it alone.
Easy Browse preset page showing each controller button's job and the pointer and scroll speed sliders.
Figure 1. The Easy Browse preset shows each controller button's job, with pointer and scroll speed sliders.
A row in InputConfig's editor with its Options open: rows where F13 to F16 move the pointer up, down, left and right and F17 clicks.
Figure 2. The same idea as Mouse Keys, on keys you choose: F13 to F16 move the pointer and F17 clicks, with a speed slider on each row.
  • On or off. Go to System Settings, Accessibility, Pointer Control, Mouse Keys.
  • Keys. 7, 8, 9, U, O, J, K and L move, I clicks, M holds and Period releases.
  • Typing stopped. Mouse Keys is on. Turn it off.
While Mouse Keys is on, the keyboard is a mouse and not a keyboard.
How do I turn off Mouse Keys on a Mac?
Open System Settings, click Accessibility, then Pointer Control, and turn Mouse Keys off. If the option to toggle it with the Option key is on, pressing Option five times turns it off too.
What is the shortcut for Mouse Keys on a Mac?
Press the Option key five times, once that option is turned on in the Mouse Keys settings. Apple's Accessibility Shortcuts can switch it on and off as well.
Why can I not type when Mouse Keys is on?
Apple notes that the keyboard and the numeric keypad cannot enter text while Mouse Keys is on, because those keys are moving the pointer. Turn it off to type.
Does Mouse Keys work without a numeric keypad?
Yes. On the main keyboard, 7, 8, 9, U, O, J, K and L move the pointer, I clicks, M presses and holds the button, and Period releases it.
How do I right click with Mouse Keys on a Mac?
Turn on Alternate pointer actions in System Settings, Accessibility, Pointer Control. It lets a keyboard shortcut, a switch or a facial expression perform a right click or a double click.
