How to play Bloons TD 6 with a controller on a Mac
Turn the sticks into a pointer and the buttons into the game's hotkeys with a mapper: Bloons TD 6 runs natively on the Mac, and on Steam it lists no controller support. It is a game about putting a monkey exactly where you want it and clicking an upgrade, so a mouse is what it expects.
A controller can do that job well once InputConfig, the free mapper I make, gives it a pointer and the hotkeys, and for a long session on a sofa it is a lot more comfortable than a trackpad.
  1. Steps
  2. Check the game's hotkeys
  3. Build the layout
  4. Make it comfortable
  5. If a button does nothing in the game
  6. Play co-op and the rest
  7. The short version
  1. Check your hotkeys in Bloons TD 6's options.
  2. In InputConfig, make a new preset and choose Automatically insert available inputs.
  3. Give the sticks pointer movement, the right trigger a left click, and the buttons the game's hotkeys.
  4. Press Activate and start a map.
Bloons TD 6 has a keyboard hotkey for nearly everything, and that is what makes a controller practical:
  • Towers. Each has a letter: Dart Monkey is Q by default, the hero is U.
  • Upgrades. Comma, period and slash for the three paths.
  • The round. Space starts it and toggles fast forward.
  • Selling and targeting. Backspace sells the selected tower, and Tab changes its targeting.
  • Several at once. Holding Shift while placing keeps the tower selected so you can place several.
Every one of these can be changed under the game's Options, in its hotkey settings, so check yours before you build the layout.
Build the layout
ControllerSendsWhy
Left stickPointer, slowLands a tower on the exact spot
Right stickPointer, fastCrosses the map
Right triggerLeft clickPlace, select, buy
A / CrossSpaceStart round, fast forward
B / CircleEscapeBack out
D-pad up, right, downComma, period, slashThe three upgrade paths
D-pad leftBackspaceSell
RB / R1TabTargeting
LB / L1Shift, heldPlace several
X, YYour two most used towersDart Monkey Q and the hero U to start
  • You: In InputConfig, make a new preset, choose Automatically insert available inputs, and give these rows their outputs. The two sticks are four pointer rows each: set the left stick's speed low and the right stick's high.
  • InputConfig: Moves the pointer and sends the hotkeys while the preset runs.
  • Check: Press Activate, start a map, and place a Dart Monkey with X and the right trigger.
A Bloons TD 6 layout drawn on a DualSense Edge in InputConfig: upgrade paths on the D-pad, start round on the bottom button, targeting on the right bumper.
Figure 1. Upgrades on the D-pad, the round on the big button.
It takes a few minutes, once.
Make it comfortable
  • Ramp-up on the slow stick. With Ramp-up on, a small push creeps and a held push travels, which is what you want when the gap between two paths is a few pixels.
  • More towers on chords. Give the face buttons more tower letters with While also holding the left trigger, and the left trigger becomes a shift key for a second set of four.
  • Abilities. Activated abilities have number keys. Put the ones you use on the stick clicks or back paddles.
  • Turn it on with the game. In the preset's Automation & Gaming Utilities section, add Bloons TD 6 under Activate when these apps are in front, and turn on Switch presets when the front app changes in Settings, Advanced.
Two pointer speeds, one per stick, are what make tower placement easy.
  1. Activate the preset. Rows only work while it runs.
  2. Check the hotkey. If you changed a hotkey in the game's options, change the row to match.
  3. Allow Accessibility. Without it no app can press keys or click for you. The menu bar icon turns orange when a running preset needs it.
The game only ever sees a mouse and a keyboard, so if the key works on the keyboard, the row can send it.
Co-op is online, so each player is on their own device and their own controller. Everything here works the same in co-op, races and boss events, because the game only ever sees a mouse and a keyboard.
  • Pointer. It is slow on the left stick and fast on the right, with the click on the right trigger.
  • Hotkeys. Put upgrades on the D-pad, Space on A, and towers on X and Y.
  • Comfort. Add Ramp-up on the slow stick, and a chord for more towers.
A mouse game, played from the sofa, with every hotkey under a thumb.
Does Bloons TD 6 have controller support?
Steam lists none for it. The game is built for a mouse and keyboard, and a mapper is how you play it from a controller: the sticks move the pointer and the buttons send its hotkeys.
What are the Bloons TD 6 upgrade hotkeys?
By default comma, period and slash upgrade the top, middle and bottom paths, Backspace sells and Tab changes targeting. They can be changed in the game's options.
Can I play Bloons TD 6 with one hand?
Yes. Put the pointer, the click and the upgrade keys on one half of the pad. The one-handed Mac guide has more.
