Do DualSense adaptive triggers work on a Mac?
Only in games that add support for them. Apple's game controller framework lets a Mac game set the DualSense trigger resistance, so it depends on the game. InputConfig does not drive adaptive triggers or the finer haptic effects. It drives the rumble motors, with a strength and a duration on each row.
I make InputConfig, a free Mac app that maps a controller to keys and mouse. This page says plainly what works, so you do not spend an evening looking for a setting that is not there.
Know what each part needs
| Feature | On a Mac |
| Buttons, sticks, triggers | Read by macOS and by InputConfig, over Bluetooth or USB |
| Touchpad and motion sensors | Read by InputConfig, and by games that use them |
| Light bar | Set by InputConfig, to any color |
| Rumble | Driven by InputConfig per row, and by games that support it |
| Adaptive trigger resistance | Only in games that support it. Not in InputConfig |
| Fine haptic effects | Not in InputConfig |
Use rumble as feedback instead
- You: Expand Options on a row and tick Vibrate in the Feedback box. Set Strength and Duration.
- InputConfig: Buzzes the controller each time that row fires.
- Check: Press the button. You feel a short buzz.
A buzz on a press tells your hand the button fired, which is most of what people want from haptics outside a game.
If a game should support the triggers and does not
Try the controller on a USB-C cable, and check the game's own controller settings for a haptics or trigger effect switch. I have not tested which Mac games use the triggers, so I will not list any here.
- Adaptive triggers. They work only where the game supports them.
- InputConfig. It drives rumble and the light bar, and not trigger resistance.
Does InputConfig support DualSense adaptive triggers?
No. InputConfig drives the rumble motors only, with a strength and duration per row. Trigger resistance and the finer haptic effects are not part of it.
Can a Mac game use adaptive triggers?
Yes, if the game adds support through Apple's game controller framework. Whether a given game does is up to that game.
Can I make the DualSense rumble on a Mac?
Yes. In InputConfig, tick Vibrate in the Feedback box of a row's Options, and set its strength and duration.
