Is there BetterJoy for Mac?
No, and on a Mac you mostly do not need one. BetterJoy lets a Switch Pro Controller, Joy-Cons and the Switch SNES controller work with emulators and as a generic XInput controller, and its setup steps are for Windows: drivers to install, then an .exe to run. macOS 13 and later reads Joy-Cons and the Switch Pro Controller over Bluetooth with no driver, so games and emulators that support controllers see them directly. Joy-Con Toolkit is a separate project, and its GitHub page lists Windows prerequisites.
I make InputConfig, a free Mac app that covers the part macOS leaves out: mapping those controllers to keys and the mouse for games that ignore them.
- Hold the Sync button on the Joy-Con or the Pro Controller until its lights move.
- Open System Settings, Bluetooth, and click Connect.
- Open System Settings, Game Controllers, and press a button to check it is live.
- In an emulator, assign the buttons in its own controls screen.
- For a game that ignores controllers, press Scan on a row in InputConfig and press a button.
Know what macOS already does
- Pairing. Joy-Cons connect one at a time over Bluetooth, each as its own controller, and macOS 13 and later can also combine them into a pair. The Switch Pro Controller pairs the same way.
- Games. A Mac game with controller support sees them like any pad.
- Emulators. Emulators that read controllers assign them in their own controls screen.
Connecting Joy-Cons and connecting a Switch Pro Controller have the steps. The job BetterJoy does on Windows is built into macOS 13 and later.
Match the rest of BetterJoy on a Mac
| In BetterJoy | On a Mac |
| Use the controller in emulators | macOS lists it as a game controller, and the emulator reads it |
| Act as a generic XInput controller | Not needed for Mac games, which read the controller directly. InputConfig does not present a controller of any kind |
| Remap SL, SR and Capture to keys | InputConfig binds any button it receives, a Joy-Con's rail buttons included, to a key, a click or a shortcut |
| Gyro as a mouse | InputConfig's Motion rows read a Joy-Con's gyroscope and accelerometer when macOS reports them |
Buttons and sticks come through on a Mac, and a Joy-Con's motion sensors come through when macOS reports them.
Map them for games that ignore controllers
- You: Add a row to a preset, press Scan and press a button on the Joy-Con or the Pro Controller. Pick the key or click the game expects.
- InputConfig: Binds the row to that button, and turns a stick into WASD or the pointer.
- Check: Activate the preset and press the button in the game.
A single Joy-Con held sideways works as a small gamepad or a one-handed mouse. Joy-Cons on a Mac shows both. Where a game takes only the keyboard, the controller can type the keys for it.
Know what Joy-Con Toolkit is
Joy-Con Toolkit is an open-source project apart from BetterJoy. Its GitHub page, which I read on October 27, 2026, lists Windows prerequisites, the Visual C++ 2017 redistributable and, on older Windows, .NET Framework 4.7.1, and I found no Mac build. I have not used it, so check the project's page for what it does. On a Mac, the pairing steps above are what to use. Neither BetterJoy nor Joy-Con Toolkit has a Mac version that I could find.
What a Mac cannot do here
- XInput. InputConfig sends keyboard and mouse input and does not create a virtual Xbox controller.
- The IR camera and NFC. macOS does not pass them through. A Joy-Con's motion reaches InputConfig only when macOS reports it.
- The cable. A Switch Pro Controller sends nothing a Mac reads over its USB cable, so use Bluetooth.
On a Mac these controllers are Bluetooth gamepads with buttons and sticks, and that covers most uses.
- BetterJoy. It is a Windows program.
- On a Mac. Pair over Bluetooth on macOS 13 or later, and games and emulators see the controller.
- Extra. InputConfig maps it to keys and the mouse.
Pair the controller first, because on a Mac, pairing does the job BetterJoy does on Windows.
No. BetterJoy's setup is for Windows. A Mac does not need it for the main job, because macOS 13 and later reads Joy-Cons and the Switch Pro Controller over Bluetooth with no driver.
Is there a Joy-Con Toolkit for Mac?
I did not find one. Joy-Con Toolkit's GitHub page lists Windows prerequisites. On a Mac, pair the Joy-Cons over Bluetooth in System Settings on macOS 13 or later.
How do I use Joy-Cons with an emulator on a Mac?
Pair each Joy-Con in System Settings, Bluetooth, on macOS 13 or later. An emulator that reads controllers then lists them in its own controls screen.
Can I use Joy-Con gyro as a mouse on a Mac?
When macOS reports a Joy-Con's gyroscope and accelerometer, InputConfig's Motion rows read them, and Motion Cursor or Gyro Aim moves the pointer by tilt. The stick can move the pointer too.
Can a Mac make a Switch controller act as an Xbox controller?
Not with InputConfig, which sends keyboard and mouse input and creates no virtual controller. Mac games with controller support read a Switch controller directly, so they do not need it to.
