Built-in preset
Variable Sensitivity preset
Download InputConfig on the Mac App StoreThis preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
In this showcase preset, both sticks move the pointer, the right with the Smooth curve and the left with Aggressive. Move each and feel the difference. Then open the rows to see the setting.
Compare the two response curves by moving each stick at the same depth
Where it is in the app
Every binding
InputSendsOptionsNote
Left stick rightMouse motion right (speed 14)variable sensitivity; Aggressive curve; deadzone 10%Pointer right, aggressive curve
Left stick leftMouse motion left (speed 14)variable sensitivity; Aggressive curve; deadzone 10%Pointer left, aggressive curve
Left stick downMouse motion down (speed 14)variable sensitivity; Aggressive curve; deadzone 10%Pointer down, aggressive curve
Left stick upMouse motion up (speed 14)variable sensitivity; Aggressive curve; deadzone 10%Pointer up, aggressive curve
Right stick rightMouse motion right (speed 28)variable sensitivity; Smooth curve; deadzone 10%Pointer right, smooth curve
Right stick leftMouse motion left (speed 28)variable sensitivity; Smooth curve; deadzone 10%Pointer left, smooth curve
Right stick downMouse motion down (speed 22)variable sensitivity; Smooth curve; deadzone 10%Pointer down, smooth curve
Right stick upMouse motion up (speed 22)variable sensitivity; Smooth curve; deadzone 10%Pointer up, smooth curve
A / CrossLeft clickLeft click
9 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
  • Smooth. It is for pointing, and for hands that shake.
  • Aggressive. It is for games where reaching full speed quickly matters.
  • Linear. It is the third choice, and the one for MIDI and scrolling.
Move both sticks for ten seconds and you will know which curve you want.
Download
