Stacked Outputs preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
In this showcase preset, one button fires Space, a right click, and a MIDI note together, says Hello, and vibrates. It exists to show that outputs stack: the plus button on a row adds another output and all of them fire in parallel.
A = parallel output stack (key + click + MIDI + speech). B = parallel keystroke pair. Different from a macro: no delays, no sequence; these fire simultaneously.
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| A / Cross | Space, Right click, MIDI note 60 (C4), velocity 100, channel 1 | vibrate; speaks "Hello" | Space, right click, a MIDI note, speech, and a rumble, together |
| B / Circle | Command 4 | Command 4 (two keys at once) |
2 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Add an output. The plus button on a row adds another output, and all of them fire together.
- What it is for. It suits a game action that is also logged in a DAW, or a key that is confirmed aloud.
One row can do several jobs, so you rarely need two buttons for one moment.
Download
- Stacked Outputs presetOne press fires keystroke + mouse + MIDI + speech together 3 KB
