MIDI: Transport Control preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This preset gives you hardware transport control from a controller: A sends MIDI Start, B sends Stop, X sends Continue, the bumpers send Program Change 0 and 1 to switch patches, and the D-pad sends CC 7 for volume. Transport messages are real-time MIDI, so any DAW set to follow external MIDI transport responds.
A = Start, B = Stop, X = Continue, LB/RB = patch 1/2
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| D-pad up | MIDI CC 20 channel 1 | Volume up trigger (CC 20) | |
| D-pad down | MIDI CC 21 channel 1 | Volume down trigger (CC 21) | |
| A / Cross | MIDI transport start | Transport start | |
| B / Circle | MIDI transport stop | Transport stop | |
| X / Square | MIDI transport continue | Transport continue | |
| LB / L1 | MIDI program change 0 | Patch 1 (program change 0) | |
| RB / R1 | MIDI program change 1 | Patch 2 (program change 1) |
7 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- DAWs that ignore MIDI transport. Replace the outputs with keyboard shortcuts such as Space, Return and R, and the preset works the same from the outside.
- A full remote. The control surface guide has a complete layout.
Set the DAW to follow external MIDI transport, then the three buttons run it.
Download
- MIDI: Transport Control presetDAW remote: start, stop, continue, program change 5 KB
