FPS (8BitDo) preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
This is the shooter layout for 8BitDo's button arrangement. It suits the Pro 2, the Ultimate and the SN30 Pro+ paired in the mode 8BitDo lists for Apple devices: D on the Pro 2's switch, B and Start on the SN30 Pro+. Pads that InputConfig reads in X mode over a USB cable can use it too. Which mode for your model.
FPS layout tuned for 8BitDo triggers
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Left stick left | A | Strafe left (A) | |
| Left stick right | D | Strafe right (D) | |
| Left stick up | W | Walk forward (W) | |
| Left stick down | S | Walk back (S) | |
| Right stick left | Mouse motion left (speed 22) | Look left | |
| Right stick right | Mouse motion right (speed 22) | Look right | |
| Right stick up | Mouse motion up (speed 14) | Look up | |
| Right stick down | Mouse motion down (speed 14) | Look down | |
| Left trigger | Right click | Aim down sights (right click) | |
| Right trigger | Left click | Fire (left click) | |
| D-pad up | Scroll up (one step) | Next weapon (scroll up) | |
| D-pad down | Scroll down (one step) | Previous weapon (scroll down) | |
| D-pad left | Q | Ability or lean (Q) | |
| D-pad right | F | Use (F) | |
| A / Cross | Space | Jump (Space) | |
| B / Circle | C | Crouch (C) | |
| X / Square | R | Reload (R) | |
| Y / Triangle | 1 | Weapon slot 1 | |
| LB / L1 | 4 | Weapon slot 4 | |
| RB / R1 | Middle click | Middle click (ping or melee in many games) | |
| L3 (left stick click) | Shift | Sprint (Shift, held) | |
| R3 (right stick click) | E | Use (E) | |
| Back / Share / Select | Tab | Scoreboard (Tab) | |
| Start / Options | Escape | Menu (Escape) |
24 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Buttons that do nothing. Check the mode switch on the back first. The 8BitDo page explains each position.
With an 8BitDo pad, the mode it was paired in decides almost everything.
Download
- FPS (8BitDo) preset8BitDo Pro 2, Ultimate, SN30 Pro+ in D mode 13 KB
