Deadzone Calibration preset
This preset ships inside InputConfig, free on the Mac App Store. You don't have to make an account, there are no subscriptions, and nothing is locked. Optimized for Apple silicon.
In this showcase preset, the right stick has a wide Deadzone and a Full push at that reaches full output early. The left stick is tight. Move each and see how much travel does nothing and where full speed arrives. Press Adjust live on a row for the live plot.
Open a stick row's Options and choose Adjust live to see the live ring visualizer
Where it is in the app
Every binding
| Input | Sends | Options | Note |
| Left stick right | Mouse motion right (speed 24) | variable sensitivity; deadzone 5% | Pointer right, tight deadzone |
| Left stick left | Mouse motion left (speed 24) | variable sensitivity; deadzone 5% | Pointer left, tight deadzone |
| Left stick down | Mouse motion down (speed 20) | variable sensitivity; deadzone 5% | Pointer down, tight deadzone |
| Left stick up | Mouse motion up (speed 20) | variable sensitivity; deadzone 5% | Pointer up, tight deadzone |
| Right stick right | Mouse motion right (speed 24) | variable sensitivity; deadzone 18%; outer 85% | Pointer right, wide deadzone and outer limit |
| Right stick left | Mouse motion left (speed 24) | variable sensitivity; deadzone 18%; outer 85% | Pointer left, wide deadzone and outer limit |
| Right stick down | Mouse motion down (speed 20) | variable sensitivity; deadzone 18%; outer 85% | Pointer down, wide deadzone and outer limit |
| Right stick up | Mouse motion up (speed 20) | variable sensitivity; deadzone 18%; outer 85% | Pointer up, wide deadzone and outer limit |
| A / Cross | Left click | Left click |
9 rows. Button names are the Xbox / PlayStation pair the editor shows; a Switch Pro Controller fires by position. Options are the row settings that differ from the defaults.
Notes
- Numbers for a tremor. The right stick's settings are close to what suits a hand tremor or a stick with limited travel. The tremor guide starts from numbers like these.
- The live plot. Press Adjust live on a row to watch where the stick rests and where full speed arrives.
A wider deadzone trades a little travel for a pointer that stays put.
Download
- Deadzone Calibration presetRight stick wide deadzone + outer saturation, left stick tight 7 KB
