Trackpad gestures not working on a Mac
When a trackpad gesture stops working on a Mac, it is usually switched off, or it moved: every gesture has its own switch in System Settings, Trackpad, and three-finger drag lives in Accessibility. Check the switch for that gesture first, then climb the ladder below. The trackpad test shows whether the trackpad is seeing your fingers at all.
  1. Open System Settings, Trackpad.
  2. Check the gesture is on in Point & Click, Scroll & Zoom or More Gestures.
  3. For three-finger drag, open Accessibility, Pointer Control, Trackpad Options.
  4. Restart the Mac.
  5. Test the trackpad with a trackpad tester.
Find the switch for the gesture
  • Point & Click. Tap to click, secondary click, and Look up.
  • Scroll & Zoom. Natural scrolling, pinch to zoom, smart zoom and rotate.
  • More Gestures. Swipe between pages, swipe between full-screen apps, Notification Center, Mission Control, App Exposé and Show Desktop.
  • Three-finger drag. In System Settings, Accessibility, Pointer Control, Trackpad Options, choose the dragging style.
A gesture that stopped after an update is often just switched off, so check its switch before anything else.
If a gesture still does nothing
  1. Test the trackpad. The trackpad test shows touches and clicks. If nothing registers there, the trackpad or its connection is the problem.
  2. Check a Magic Trackpad's battery and Bluetooth. A low battery or a weak connection drops gestures first.
  3. Quit apps that change gestures. A gesture app or a mapper can take a gesture before macOS sees it.
  4. Restart the Mac. It reloads the trackpad settings.
  5. Try another user account. If gestures work there, the problem is a setting in your own account.
Know what one app can do about it
Swipe between pages only works in apps that support it, such as Safari and the Finder, and some apps use their own gestures. If what you want is a click or a key from somewhere other than the trackpad, a mouse side button or a controller can send it. A mouse back button that does nothing covers the most common case.
A row in InputConfig's editor with its Options open: controller rows that open Mission Control, move to the previous and next desktop, and open Launchpad.
Figure 1. InputConfig cannot repair a gesture. It can put the same actions on buttons: Mission Control, previous desktop, next desktop and Launchpad.
  • Most gestures. System Settings, Trackpad, three tabs.
  • Three-finger drag. Accessibility, Pointer Control, Trackpad Options.
  • Nothing at all. Test it, then check the battery, other apps and a restart.
Why did my trackpad gestures stop working on my Mac?
Usually the gesture is switched off in System Settings, Trackpad, or an app that changes gestures has taken it. Check the switch, quit gesture apps, and restart.
Where is three-finger drag on a Mac?
In System Settings, Accessibility, Pointer Control, Trackpad Options, where you choose the dragging style.
Why is the three finger swipe not working on my Mac?
Open System Settings, Trackpad, More Gestures and check that the swipe is on. Three-finger drag is a separate setting under Accessibility, Pointer Control, Trackpad Options, and both use three fingers, so I would check the two places together. If both look right, quit any gesture app and restart.
Why are gestures not working on my Magic Trackpad?
Check its battery and Bluetooth connection first, because a low battery or a weak connection drops gestures before anything else. Then confirm the gesture is on in System Settings, Trackpad, and use the trackpad test to see whether the Mac registers your fingers at all.
